I've used Eurekazone products for quite a few years now. I'm just an amateur woodworker, but no more messing with large sheets of plywood on a table saw or trying to keep my circular saw running straight on its own. I use the Eurekazone gear plus a compound sliding miter saw for most of my work.
Their philosophy - they call it the "dead wood concept" is to improve the safety of woodworking by having the wood stay put and moving the saw with the hands (and fingers) well away from the cutting area. The exact opposite of a table saw or router table, ... more like a circular saw or hand router, but with much MUCH more control. Think of a drill press with the wood clamped down in a safe manner.
First rate stuff made in the U.S. (Florida) by a great little company. I'd strongly recommend their products. Heavy duty stuff. Very clean and precise cuts. They actually use their own products to cut many of the components.
I have used a number of their tracks and the older non-adjustable Square (for fast 90 degree miter cuts) for many years, their Universal Edge Guide (UEG - newish to me), and their Super Smart Router Kit (SSRK - also newish to me. I recently found a used EZ-One Woodworking Center for sale near me and bought that.
The current philosophy is to use the Universal Edge Guide (UEG) to cut down the lengths of plywood - providing each piece with clean edges and perfectly equal widths. Then they use the Square with a shorter track to do all the cross cuts to their final size (the Cabinetmaker setup can be used to make repeated cross cuts of equal size). The white plastic Anti-Chip Edge on the track, along with the saw base insert, provides the clean cut edges (like a zero clearance plate on a table saw), and also shows you exactly where the cut will be. The Super Smart Router Kit is used to make dadoes, rabbets, and other cuts (one advantage is that you can create about any custom width dado/rabbet with a smaller straight bit by using the SSRK controls).
I previously bought their saw with the base pre-attached, but recently decided to swap out an older style base with a newer style, and it was a pretty easy process. I think most folks could do it themselves just fine.
