What approach did you recommend? Picture?Yes but you will need a new pattern for each size of door. The flat run is to compensate for different sized doors using the same arched pattern.
Hmmm...actually it is a style of door (Cathedral Arch) that just happens to allow for the possibility of using the same template for multiple widths of door:Yes but you will need a new pattern for each size of door. The flat run is to compensate for different sized doors using the same arched pattern.
