1 - 2 of 2 Posts
Discussion Starter #1
Need to discuss with someone who has assembled the Milescraft 3D Router Pantograph. The assembly process is fairly simple except for a few subtle areas. One of these has me stumped. I plan to contact Milescraft when they open Monday but I was hoping to be able to use the pantograph this weekend.
The problem I am having is connecting the router adapter plate to the guide arm and the left tube. The guide arm and other tube are placed in adapter pivots and a pivot cap is place over the tube and tightened and held down by two screws. There is a slot on the adapter pivot to slide a nut into for the screw to attach and tighten down. The problem is the nut is clearly larger than the slot it is supposed to slide into. This I can see clearly and pressure on the nut will not slide it into the slot. I hesitate to put additional pressure on the nut for fear of breaking the plastic adapter pivot.
Hi
This may help
YouTube - 1298 Pantograph from Milescraft
1 - 2 of 2 Posts
