1 - 4 of 4 Posts
· Registered
I am new to this forum and new to using a Cnc. I built my own Cnc and am using Mach3 to run it. I am retired and don’t have a wad of cash to spend on software. I can find gobs of STL files but converting them for use on a Cnc router I find to be almost impossible. Is there any web sites that offer Cnc 3d models that are in dxf or g-code format? I am willing to pay for the files, it’s just finding them. Can anyone help with this?
· Registered
Which CAD/CAM software are you using? I wouldn't use G-code that you didn't produce for your machine. There are a ton of SVG files out there that you can import into most CAD/CAM software. With that software you will define the toolpaths that will generate the G-code for your machine. I personally use Vectric's VCarve Pro, which is very popular, but is a little expensive. You can get their desktop version for about half price and then upgrade to the Pro version at a later date. There are a lot of really good and informative videos out there on using Vectric products for CNC.
· Registered
Yes. You can use intermediary software to convert STL files to dxf.
I am going to recommend Blender 3d because its free though it has a steep learning curve if you want to use it for CNC pattern modeling. Blender can convert STL to dxf. So import as STL and then export to dxf is really basic.
You do have to enable the STL and DXF add-ons in the edit tab. They are part of the program but aren't enabled to keep the GUI clean if not needed.
· Registered
I would recommend you download and use FREEWARE Inkscape and use SVG files instead. Inkscape can write g-code directly too.
If you want a low cost CAD/CAM I would recommend HEEKS-CNC 1.4 that only cost EU10. I am using it.
1 - 4 of 4 Posts
