Hey folks, I first apologize if this has been discussed before, but I have a significant problem that is just beyond my skill level. Second, I apologize for the length of this post as without the proper description, it won't make true sense. I would appreciate any comments toward finding a solution.
Basic parameters. I'm running an AvidCNC 48x96 with an independent Lenovo PC. I work with Vectic Aspire v11 and use a separate computer for design and place the g-code file (with the proper post processor) to a thumb drive and load that onto the Lenovo with the Mach 4 to drive the CNC.
I downloaded one of the project files, the Vectric Buffalo Nickel Bank, made no modifications to the file (other than inserting the correct bit feeds and speeds) and cut it with the following toolpaths, 1) 3D roughing .25 endmill, then 1/8 inch tapered ball nose, then a 1/16 tapered ball nose for rest machining (handled by Aspire). Both heads and tails of the nickel are cut from one board in the same toolpath on a board that I have planed to the proper thickness, so I know that there are no discrepancies in material thickness.
The first cut of the tapered ball nose, using an offset toolpath. into the toolpath, for whatever reason, the Z-height changed, mid toolpath, leaving a pronounced difference. Even though I knew it was incorrect, I used the touch-plate to zero the next smaller ball nose and it cut the depth properly but it looks horrible since the z height was off.
So, I thought that maybe this was associated with the offset toolpath and switched to a raster toolpath. Well, same issue occurred. I don't think that this is an issue with the actual model as hundreds of those have been cut and I don't know of any complaints about the model on that forum. Any suggestion or advice would be appreciated.
Would you folks think that this is a Mach4 issue, machine issue, or an Aspire issue?
