B&D Router 7613 will not mount on a Bosch RA1181 table
1370 Views 6 Replies 4 Participants Last post by  mschindler
I have a Black and Decker router Model 7613. It will not mount to my Bosch RA1181 router table. Any suggestions or fixes for this?
1 - 7 of 7 Posts
welcome to the forums N/A...
is because of the hole pattern???
Welcome to the Greatest Router Circus on Earth! You’ll find it all right here...
Look online for the table manual and/or compatibility of your router with the table base plate. I kinda doubt there will be much Of a match, which means making your own holes. Or, move up to a router lift like the popular Jessem Rout-R-Lift II - it is compatible with many 3.5” diameter router motors. I really like mine and do several others here.
Thank you for your time and info.
Mike S.
BRIAN, Do you know if the lift you mentioned will fit a Bosch Table?
Thanks,
Tagwatts1
Thanks,
Tagwatts1
I have the RA1181 Bosch table - you'll have to route 1/16" off each side of the Jessem's Rout-R-Lift II phenolic top to get it to fit. Not a problem unless that idea freaks you out. Not a biggie. I used the Bosch RA1181 leveling hardware and created the holes needed to fasten it down. Works beautifully!
Mike S.
1 - 7 of 7 Posts
