HI guys & gals! I'm going straight to my problem & maybe somebody out there can help me. I have a plunge router mounted that hasn't been touched in 3-4 years. I need to change the bit coz I actually intend to use it but the dadburned thing is stuck in the plunged position, the collet wrench is MIA, & the manual hasn't been much help at all. I really need to get this routed for tomorrow -- didn't expect it to not work. Anybody? Please?
Welcome to the forum N/a . I’m sure the experts will chime in soon , but in the mean time , a brand and model may be beneficial for them to help troubleshoot the problem better
Thanks! Wasn't sure if brand names were allowed. It's a blue hawk 1314 router on a blue hawk 1034 table. The plunge lock lever just moves around & doesn't feel to be unlocking or locking anything. Let me rephrase that. The lever unlocks it but it only moves about 1/2".
Welcome Bad Gramma. Brand names are no issue and sometimes very necessary. Some routers are really bad for having the plunge tubes plug up with sawdust if run inverted for long periods of time. When that happens they need to be cleared which often means taking the plunge base off. But at the moment it's not for sure that the column lock is releasing so follow Herb's advice and see if that helps. AS far as the wrench, usually any standard wrench the right size will work. If there is room for a crescent wrench they will even work.
I have the manual. I've checked the plunge lock lever, depth stop rod & turret & locking knob, the lock bolt. It still only unplunges about 1/2". Everything turns fine. I've pretty much have it taken apart at this point & still not getting anywhere.
Sounds like you have the router out of the table, look at the base is there a hole for an allen wrench type tool to use to raise and lower the router when it is in the table? You might try turning it and see if the motor will raise up and down.
Yeah I can't get a wrench in there til I can get it unplunged. When you raise it the 1/2" it will move, it feels to be hitting something solid but there's nothing left externally for it to hit. I'm currently removing the base to see if the plunge tube are clogged.
Try unscrewing the collet all the way off. Some collets have a “lock” that won’t allow the bit to come out until you loosen it to its “unlocked” position. If you try unscrewing it all the way you will either loosen the bit, or unscrew the collet all the way which might allow you to squirt in some lube to loosen the bit. If you get the bit out you will need to clean the lube out.
There is a collet lock button just like on a dremel. My problem is that I can't get a wrench on the collet nut because it's stuck in the plunged position so I can't access the collet nut. I've never had a tool beat me before. I'm not giving up!
Except my darling hubby removed the plunge lock lever & now it won't catch to screw it back in. I love him & he can make computers do flips but it's a family joke that he's not allowed in the house with a hammer. Daddy was a master cabinet builder back in the day so what I know I picked up from him. Fixing a tool is generally a piece of cake for me but this one's kicking my butt.
The fact that it moves a 1/2 inch seems to indicate that it is plugged by either saw dust or some rust/corrosion due to the fact it has not been used for quite a while. Most likely you will have to dismantle it to clean out the tubes. Some WD 40 might loosen it up. My tools were in storage for 3 years and I am having to tear them down and remove the corrosion to put them back in working order, sounds like you have the same problem.
Getting the bit out is a separate issue.
Assuming you can lock the shaft and undo the locking nut, then the bit should come out. If not try squirting wd 40 around the bit shaft and use a block of hard wood to give a sharp tap to the bit to loosen it.
This is an older thread, you may not receive a response, and could
be reviving an old thread. Please consider creating a new thread.
