Hi- anyone in UK with experience of buying/ using BBP over here?
I buy 8'x4' sheets at £55 a pop, one a month or so. I use it cut right down to 3' sq sections or so + thinner 3' x 6" 'panel' sections. And Im fed up with it warping.
What I want to know, is by how much in a large 8'x4' sheet I should expect to be seeing it bow, or warp when I buy it. At the mo Im consistantly getting as much as a 1' bow on the short side.. and 1'- 2' on the long side. It drives me insane. And Im forced to pay for it as its ordered for me.
I dont have the option of buying elsewhere, & my building supply bloke gets the hump if I Q the warp, or even if I ask if their supplier can "please make sure its flat": which makes no difference by all accounts- their supplier says 'its how we get it/ we dont make it' (Ive called them) and/ or 'once its cut up the tension will release & it will flatten'.. it doesn't, ever, certainly not this lg sheet into 3rds even leaving it in a dry flat areas for 2 weeks its ecactly the same, and still evident (say a 1" warp along the side of a 3' sq section) once cut into my useable-sized smaller pieces.
Also both faces are peppered with annoying filled areas in odd shaped birch filler spots approx 3" x 2". All over the shop. What are these, and should I be expecting these on a £55 sheet?
Thanks, The Mascara Snake.
