Originally, the insert was proposed because routers have handles so it was wider that the baseplate (especially plunge routers) and so it was not possible to take out the router from the top to change bits if base plate mounted unless the baseplate is replaced with a larger diameter and thinker base plate.What is the benefit of an insert vs a base plate mount?
