@DMac
Are you doing this hand held or on a router table?
The easiest way would be to use a table and a flush trim bit. The flush trim bit has a bearing which is at the end of the bit away from the router. On a table mounted router, the bearing would be the uppermost part of the bit. With the template attached to your stock, you run the stock against the bit so that the bearing rides along your bit and trims the excess from your table saw plate. In this manner, you always feed the stock from right to left, with the bit to the right of the template/stock.
If you were to do this handheld , the bearing would be near the bottom and you would then keep your stock/template to the left of the bit, but still feed from right to left. It would be a lot harder to secure the stock/template in this fashion.
If you use a bushing, you have to take into account the offset of the bushing, meaning the template would have to be smaller than the finished size of the insert. Depends on the OD (outside diameter) of the bushing and the size of the bit. You don't need a bearing with a bushing.
Hope that all makes sense.
