Has anyone had any experience with the Beadlock Pro Joinery jig that Rockler is selling?
Steve Bolton
Steve Bolton
Hamlin said:Hi,
I understand the "theory" behind these but, this is overkill. A simple "floating tenon" can't be beat. It doesn't require extra tooling nor the time required to get the setup done.
Just my $0.02 worth.
If I stepped on any toes here, I apologize.
harrysin said:Bj., as I have confessed on many occasions, at times I can be a slow learner so please be patient with me. I do not understand how the multi dowel shown in shot 0210 was made with the cutter shown in shot 0213. Could you please be patient with me and take some shots holding the bead against the cutter as it would have been set-up for each of the cuts. Thanks Bj.
rmaxa said:BJ, I would be interested in some detail on your Router rail system. Did you make that or was it something you bought.
Rolf
karateed said:Thanks for the knob demo BJ....excellent....I'll follow your example and try this when I am able.
Just a quick question....why couldn't you just cut each knob off once you had the long grooves in the wood. I'm just wondering the purpose of the short grooves between each knob.
Thanks BJ.
Ed......![]()
Thanks BJ.bobj3 said:Hi Ed
It's a lathe but not like a norm lathe,,, once the long grooves are in the wood then you need to round them over ,top and bottom of the knob, so I used a double round over bit so to speak that can plunge in and do the top and the bottom of each knob at the same time plus put a small stand off on the bottom so I could have something to hold on to to drill the hole in the center of the knobs...for the tee-nut and center hole...
I didn't want to clamp the knob because it's done once it's out of the lathe I think I would put in hvy. vise marks in the wood...plus it has the small stand off on the bottom side of the knob to keep your knuckles from hitting when you crank it down when you use them.....
karateed said:Thanks BJ.
Have you tried doing twists that have a hollow center yet?
Ed......![]()
I see you have a board guiding the router and a about a 2 inch square running along that board. I thought that part was on the router crafter so I'm wondering why you are using that setup. I'm pretty new still a wood working so I hope I'm not trying your patience and I do appreciate your answers very much.bobj3 said:Hi Ed
In one of the snapshots you will see one I made,,,it's not a big one...
( 1 1/4" OD x 12" long)
Along time ago I had the same tool and made many rope items,lamps,candle stands,etc. and the router lathe can do that job very well...
But I got bored with the lathe and sold it off then I saw one on eBay so I got one more, I must have gotten smarter since then,,,, from along time ago because I can see many new ways to use the machine now..![]()
