1 - 11 of 11 Posts
I have recently bought a Bosch POF 1400 ACE plunge router. I want to mount on a router table. I would like to know how to have switch control without having to hold the power on/off switches
Hello Veera, welcome to the forum.
I have heard that some users clamp the trigger switch in the on position with a cable tie or a piece of velcro.
Do you need constant pressure on BOTH parts of the switch to operate?
You will need a separate on/off switch mounted on the table.
MAKE SURE YOU UNPLUG THE ROUTER BEFORE MAKING ANY CUTTER CHANGES......
Super Moderator
John
Hello and welcome to the forum. Veera
Ross
Welcome to the forum Veera.
I don't have that brand, but my Triton router is made the same with the switch. I took the switch apart and there was a small spring and pin. I removed those. Now the router stays on all the time. I plug all of my table mounted routers either into a power strip or a toggle switch mounted on the outside of the router table for easy access. If I am going to use it hand-held (which I seldom do) I can pull the trigger to start and stop it. Hope this helps. Malcolm / Kentucky USA
triton router...
Hi Malcolm, what model is your Triton?
Can you post a picture.
I have not seen a Triton router with a trigger switch.
Hi Malcolm, although that switch, from that photo seems slightly different to mine, I would not call that a 'trigger switch'.
To my mind, a trigger switch is built into the handle and is compressed by the fingers holding the handle - like the pistol grip on a hand gun..
Does your switch have the sliding lock to prevent accidental switching on?
I also have 2 Tritons - they are great...
Discussion Starter · #11 ·
Thank You so much for the suggestion. I tied both the switches with the cable tie and installed a separate switch to control the power supply. It works for me . I will post some photos later so that it can be useful for new woodworkers like me.
- Veera
1 - 11 of 11 Posts
