Best distance to position a combo miter guage track
2909 Views 12 Replies 6 Participants Last post by  ranman
Is there a best or ideal distance to position a miter track away from the bit?
Do you position the clamp groove or the miter groove closest to the bit?
1 - 13 of 13 Posts
When you say clamp grove are you talking about the feather board? If so then it depends on how much adjustment your feather board has. You want to be able to hold narrow stock tight to the fence so say you are working with a 3/4" piece of wood. You would position your fence so that it would hold the wood tight. That would determine where you would put your miter track. Don't worry about wide boards you can hold them by hand. When using the miter gauge (usually for doing the ends of rails) you want the miter gauge close enough so that the wood can be held without pivoting. You can attach a narrow board to the miter gauge to bring it right up to the fence for stability. My miter track is about 6" from the fence.
Reactions: 3
I probably should have looked at the feather boards to see how adjustable they are, or the adjustment range they have. I suppose they come in a lot of different sizes. I'll check on that. Thanks.
Rather than install tracks in my table top I made a jig for doing the ends of things like stiles or half lapping that just runs along the edge of my table. You can do much the same thing with featherboards if you make them yourself and make them longer so that you can clamp them to the edge of the table.
Reactions: 3
Do you have any pictures? It doesn't seem to be something that's needed a lot.
The range of adjustment depends on the feather board. A TTrack on the fence should be high enough so you can attach a featherboard vertically. I think it is worth the effort to build a fairly tall fence or even split fence. There are featherboards meant for installing on the fence and they are not as tall as the most common ones. Pix of pair of featherboards on router table, holding small piece down and to the fence. Also a pix of shop made featherboard that uses a star knob and Tbolt, on a table saw but usable on a router table IF you cut a slot for the bolt to fit on a slot at any distance.
Here some that show long boards, can be used W/O miter slot just clamps.
Reactions: 2
Post #72 on page 8 of this thread: https://www.routerforums.com/tools-woodworking/102826-shop-hacks-bobj3-corner-8.html If I'm doing a job where I want some blowout protection then I just throw one together out of shop scrap so that I have a fresh edge behind my work piece. On the first pass it gets profiled the same as the piece I'm working on then. It takes maybe 5 minutes to throw one together.
This jig has a couple of advantages over a sled that rides against the fence or in a miter slot:
-Your work sits flat on the table instead of on top of the sled so you don't need to worry if your bit is going to be long enough.
-As stated it gives blowout protection which not all sleds will do and as one picture shows you can clamp your work to it just like you can a sled.
-It costs nothing to make. Just grab some appropriate shop scrap and screw /or glue and brad nail it together.
Reactions: 2
Tom and Herb, nice looking setups.
Chuck....... Takes a long time to get to that page. Soo much to read as I scroll slowly down all those ideas.
Thanks guys, it gives me something to ponder I'm going to look at feather boards to see how many shapes and sizes are out there. I don't think I want to make one.
Here is a link to a youtube video that past member Claudio Botelho from Brazil made years ago. It's really simple. He's using a bandsaw but it will work on a table saw too, the gaps between the fingers would be wider. He finishes the featherboard in the first minute of it.
I also am a "no miter track" guy. I can clamp feather boards to my table and fence, works just fine. My router base plate is large, so the tracks would be a good ways from the bit anyway
Reactions: 3
Doggone, I sure like information rich posts like these. Lots of practical methods and approaches. Love this place.
I agree Tom. What did our ancestors do without forums and You Tube? I'm a visual person, so words alone don't
always paint a picture for me.
Reactions: 2
1 - 13 of 13 Posts
