I just built a new router table and used the CMT top because it was the best design I could find for the money ($100.oo bucks)
It's great, it can be used just like the Oak-Park and use all the fixtures they make or you can take the bits out from the top and with the swing fence you don't need to remove the fence to replace a bit plus it will let you use up to 4 1/2" dia. bits and with just a little rework you can use the P.C. brass guides, plus you can use it from the front or the back by poping out the router plate and just turn it around and drop it back in.
In this way you can use the T-track or have a wide base for wide stock.
The port hole for the router is off set from the center of the table by about 6".
And the real plus it's Industrio Phenolic Routertop with Alum.Insert Ring
http://www.sommerfeldtools.com/products.asp?ID=6
http://www.sommerfeldtools.com/closeouts.asp
List of 278.oo on sale for 99.oo
It's should last for a long time..
,neat top....
Just a NOTE,,,some Great prices on router bits (close out specials)
do a search on the web page for bits (it will show a picture of them)
Just my 2 cents
Bj
