That depends, are you going to use the router in the table only. Will you be using a router lift, if so what type.
This router will be dedicated for the "Veritas Table system" from Lee Valley. I doubt that a lift will be used.ejant said:That depends, are you going to use the router in the table only. Will you be using a router lift, if so what type.
ejant said:Looking on the Lee Valley site they show the router being used as the Hitachi 3.5 hp model.
IMO I'd look for a router that is plunge and comes as high as possible to the base for ease of changing bits.[/QUOTE
How do you regard Bosch or PC. Price will have nothing to do with my purchase. First and Foremost IS QUALITY. I will appreciate your suggestions.
Thank You Very Much.
Thanks for the information. I will check out the PC as well as the DeWalt to see which one feels best and go from there. Once again, Thanks a Lot.ejant said:I have a Bosch 2.5 pulunge and don't like it because of the tightness around the baseplate.
The routers I use the most are a PC 7581 it is basically just a moter as the whole base was remove and is in an Incra table w/twin leanear fence.
In the router workshop table I use a Dewlt 625.
Both of these get a lot of use and I guess i like them equally.
I have the hitachi also and it is set up with the large hole router workshop plate and for a hand held i use a Fien.
The Fien is an excellent hand held router.
