I'm having some difficulty keeping a brass guide centered when I change to the bit. I use the centering tool to center the guide then when I put the bit into the router, things seem to get moved. I have a PC 890 and a rockler base/table.
Also, on a side note, I'm thinking of getting a bigger router. So what I'm looking for is 2 1/2HP+ and something that is easy to change bits, that I don't have to pull the base off of. This 890 is kind of tight working quarters when using guides and can not remove the base.
Cheers'
--Kevin
Cheers'
--Kevin
