Well, you know what they say about the best laid plans . . .
I built the trestle lathe stand according to the design I posted earlier - incorporating suggestions from you folks. The top beam is 7" Wide X 5 1/4" Height. The legs are 7" X 3 1/4". I was certain I would never need to take it apart, so every joint is glued. Through mortise/tenons where the legs join the top rail and the feet. Even the stretchers across the legs are glued in place and backed up with lag bolts. The thing is massive and strong. It was all going so well until I put the lathe on top of it.
It's 5 inches too high. It seems that when I measured the spindle height on my lathe, I measured to the bed instead of to the surface of the stand. Anyway, now the thing is built and it needs to get 5 inches shorter. When I make a mistake like that, I've learned not to try to fix it immediately. The best solutions usually come after some gestation period in my subconscious.
The best plan I have come up with so far is to cut 5 inches out of the middle of the legs. Then I'll glue a scab on all 4 sides of each leg in such a way as to wrap the entire leg with a "cast", making the fix practically invisible.
However, recognizing the collective wisdom of the group, I'm asking if anyone has a better idea.
