I saved this article years ago, really liked the look of the finished lamp - wife didn't, enough said. The article shows making the joint with two passes on the TS, but it looks as if one of those bits would be perfect (and a lot easier). But the wife still doesn't like the lamp..............yes...
they work well..
LeeValley has a very good set...
Bird's-Mouth Joinery Bits™ - Lee Valley Tools
if you work out the angles you can makw the cuts on the table saw using a dado blade...
cheaper/faster...I never thought that the table saw with a dado stack would be a alternative but it does make sense. Any advantage/disadvantage or using the tablesaw.
dado blade..I saved this article years ago, really liked the look of the finished lamp - wife didn't, enough said. The article shows making the joint with two passes on the TS, but it looks as if one of those bits would be perfect (and a lot easier). But the wife still doesn't like the lamp..............
That's a pretty sweet box Bob!! I love it.That link didnt work very well, the pic is way too small, so this is the second try.
