1 - 5 of 5 Posts
· Registered
I am embarrassesed to say that I have trouble figureing out what bit diameter and guide diameter to use when pattern cutting. Does anyone have a quick and easy formula or method to determine exactly where the cut will be when using a guide? My trial and error method is getting old. Thanks in advance for any and all responses.
Happy woodworking,
Pop Pop
:eek:
· Registered
Oak Park had a very good guide. I'll see if I can attatch them. I've never tried to include or attach a picture in the forum before. :confused:
Take one half the guide diameter and subtract one half of the bit diameter.
That is the distance from the guide bushing to the final cut edge.
Hope this helps
· Banned
Draw two circles, a large one with a smaller one inside and a dot in the center. This is your visual reference. As an example call the outside circle 3/4" and the inside circle 1/2". Since all cuts will be made from the center point you would get 1/2 the size of the bit(in this case 1/4") on both sides of the center dot. To figure where you need to mark your guide spacing you subtract the bit cut (again 1/4" from the center point) from 1/2 of the guide size (in this case 3/8" from the center point) and come up with 1/8" on both sides of center. How does this work in making a pattern? Lets say you need to make a pattern for a 2" circle. If you will be using the inside of a pattern you will need a guide hole the size of your circle (2") plus the guide distance (1/8" on both sides of center) or 2-1/4" diameter hole. If you will be using an outside pattern to make a 2" circle you take your hole size (2") minus the guide distance (1/8" on both sides of center) and end up with a pattern 1-3/4" diameter. If you are only using one side of the pattern for an outside or inside cut you will use only the guide distance.(1/8", only on one side of center) Now you can change the numbers for your bit & Guide. I hope this helps.
· Registered
Hope this helps
If you want to go to the orginal post of this information check:
http://www.routerforums.com/showpost.php?p=1812&postcount=9
If you use the search function there is a lot more information in the forum. I also posted some of my table in the gallery area if they are of interest to you.
Ed
· Registered
Discussion Starter · #5 ·
Thanks guys, your information is exactly what I was hoping for. I've already made copies of the chart and diagrams and will cover them in plastic, and keep them close to my router table for a ready reference.
Pop Pop
1 - 5 of 5 Posts
