Unusual for the shaft of the bit to only go into the collet for 5/8”. Check that there is no obstruction. I would say definitely unsafe to have a 3” bit with only 5/8” inside the collet.
The collet length is 5/8”. The bit don’t want to pass through more.Unusual for the shaft of the bit to only go into the collet for 5/8”. Check that there is no obstruction. I would say definitely unsafe to have a 3” bit with only 5/8” inside the collet.
I have another idea: if I build a ticker jig attached to my base, the 2 1/2” bit could do the job. I found the 75-103 Freud bit that is 2 “ long but more expensive than 2 1/2”.The collet length is 5/8”. The bit don’t want to pass through more.
This cutter doesn’t have a Kmark. ( by the way it have rusted marks from my other router)I belive the newer cutters have K mark on the side to show how deep to inesrt the cutter into the collet.
Does you cutter have this mark?
I agree. the forces acting on that bit, spinning at such high speed, will be tremendous. You don't want to be anywhere near if that thing gets spit out of the collet.Unusual for the shaft of the bit to only go into the collet for 5/8”. Check that there is no obstruction. I would say definitely unsafe to have a 3” bit with only 5/8” inside the collet.
What was your other router? I have a Triton under my table
Did it fit properly in the other router? It fits perfectly and slides easily
Have you used the cutter in the other router. Yes I made a lot of mortises
I agree with the other memebers, that the cutter should go in further than that,
Me too
I would not use it in this configeration.
It cannot slide through and it jam inside the collet that I nee an unusual force to pull it out . I made a call to the company. They will send me a new collet. Probably I received a metric collet ( 6 mm instead of 6,35 mm).@domi125
on my routers with a similar collet style, the shaft of the bit can slide right through the end of the collet, to reach the bottom of the hollowed-out shaft of the motor (minus the recommended 1/8 “). If your bit can slide through, the router is simply not designed for the task you have in mind, but for edge routing.
If it cannot slide through, there may be some defect of shaft or collet. Either way, play it safe, don’t use..
