I'm not clear on the concept of adjusting and changing bits on a table.
- On a seamless table adjustments are made by loosening the motor. Bit changes require removal of the motor.
- On a base plate, the adjustment is made similar to #1 but the bit change is made by removing the base plate with the unit attached.
- On a lift, everything is done via crank (yes/no?)
- On routers with "cranks," adjustments and bit changes are done in place regardless of seamless or base plate (yes/no?)
- Would a Router Raizer solve all these problems on my Bosch 1617?
