Bit Recommendation?
1540 Views 6 Replies 5 Participants Last post by  Bill Franklin
Hi,
Can someone tell me what router bit is used to round the exterior edges of closet shelves made from particle board? I don't think it is a normal round over.
Thanks for your input.
Bill
1 - 7 of 7 Posts
Thumbnail Router Bits (infinitytools.com)
Personally I would use a slot cutter and use a solid wood edge band on the particle board. Then you can round this over with whatever profile you like.
A couple of other ways are in the picture linked below:
Reactions: 4
Thats what I was looking for thanks. If I was not trying to match existing I would be using plywood and doing exactly as you described. Thanks.
Typical bulknose is used in residential..
I second Doug's suggestion...
I third Doug's suggestion ;)
Thanks everyone who replied.
1 - 7 of 7 Posts
