Using the CNC you want to take several passes to cut the full depth of 2 1/4". Which means the shank of the 1 5/8" will be rubbing for half the depth and heat up the bit causing a shorter bit life. I would go with the 2" cut length bit and take several passes to help minimize the time the bit will be rubbing and heated up.
