challagan said:What blade do you scroll guru's recommend for 1/4 and 3/8 hardwood? Not double stacked, just singles. Also if I was using 1/8 and 1/4 hardwood plywood what would size blade would you use for that?
Thanks,
Corey,challagan said:Thanks guys, I have a selection of FD blades. Just wasn't sure what blades would work best in these thinner materials. I got the most out of the following link which was on Mikes page:
http://www.mikesworkshop.com/DaveG.htm#Blade Selection
challagan said:BJ, have you scrolled any 1/2 inch MDF and if so what did you find worked best for it?
Thanks!
challagan said:Thanks BJ, got a dozen of those. That's what I want to do is make templates. About the only thing my scroll saw will get used for these days.
