Hi Corey
Here's a snapshot or TWO
You don't need to use the bass guides, the 5/8" O.D. bearing works great, it fact it works better than the guide guide setup.
, just one less thing to to do.
The 5/8" OD bearings are cheap about 6 bucks and they will fit just about any 1/4" shank router bit.
They come in handy for many router jobs, I also put a rubber oil ring under the lock ring that should be used with a bit that has a bearing on it, the little set screws (2-56 x 1/8") that hold the lock ring in place,they have a way of coming out when the bit spins at 20,000 rpm. and the oil ring is just a way to keep the bearing from dropping down,I use a 1/8" oil rings hard to to get on but they don't slide down or come off easy.
Bearings from Grizzly below ▼
http://www.grizzly.com/products/g3854
Sommerfeldtools below ▼
http://www.mailwareweb.com/sommerfeld/item.asp?n=r4zz&d=131&b=1
and I'm sure you have a 1/4" lock ring on one of your bits or on a drill bit for stop coller.
NOTE*** in the picture below of the dovetail slot I used a 1/2" 8 deg.
dovetail bit for that one.
One more NOTE*** Corey .... the black plate you see in the snapshot is a base plate off a PC Router that I made fit the mounting base plate I have in this router table,They are cheap from Rockler or you can get one of the clear ones then use some double sided carpet tape and stick it the one you have
and let the router with a flush trim bit make it the right size to fit your table, a quick and easy fix for not having one that will fit you base plate
Bj
