bosch 1617 router
3K views 11 replies 9 participants last post by  MikeMa
:sad:Hello,
My Bosch router 1617 won't do anything when i attempt to start it ,it was fine two weeks ago when i last used it. No power ,no noise ,nothing. I have tried cleaning it with compressed air,nothing works any thoughts on that.I thought that maybe the brushes went bad. In the meantime I purchased the the same router at lowes so it would work on my table and other accessories as i was in the middle of some home improvements. What now.....
reelwood
welcome aboard....might be the switch or wiring??try posting in appropriate area for more and better responses......enjoy
John,Hello and welcome to router forums
How old is this router
Welcome to the forum, John.
Thank you for joining us, .
You will find many on the forum, from hobbyists
to professional with similar interest in the router and its uses.
John, Most Bosch tools use what they call "smart brushes". What they have done is embed a spring loaded plastic finger into the carbon brushes. When the brushes wear to a predetermined size the finger contacts the commutator and pushes the brushes away from the commutator to tell you it's time to replace. You might want to remove the brushes first to see if that is the problem.
#9 · (Edited)
I have had the same problem. It is the on/off switch that is the probable problem (Occam’s Razor) and the solution is to have Bosch send you a new one. Just call the toll free number. It is a very simple operation to change one. To keep the router working take the switch out, open it, clean the switch, replace and the router will probably start. Practice for replacing the switch when the new one arrives.
The switch isn't too hard.
1. Make sure the router is unplugged
2. Using a torx screwdriver remove the screws from the top cover, and pull the cover off
3. Using a flat head screw driver you can carefully pry out the switch.
4. There are two wires going to the switch. When that is connected with a knife connector that will slip off, and the other is soldered on. Follow the one that is soldered on and it is connected to the router with another knife connector. Slip off both connections, and the switch will come out. (Make note where that wire connected!)
5. The new switch will also have the one soldered on wire. Feed that wire through and connect it to where the old one was at. Connect the other wire to the switch
6. Push that switch back into the router housing. It should click in place
7. Replace the top cover and screw back on\
8. Plug in the router and test your new switch.
