Hi folks, Can anybody tell me if the 'Bosch 1617 evspk' is the same as the 'Bosch gmf 1400ce' over here in the U.K?,they seem to be identical...I cant find any sites in the U.K that sell the Bosch 1617,but they do sell the gmf! Philip.
Phillip, your question is a good one. Manufacturers play around with the HP ratings like anything else. 746 watts = 1 HP, so your 1400 watt motor is a fraction under 2 HP. I say call it a 2 HP and don't worry about it. HP ratings or watts are only a reference to compare models. A good example of this is the way routers are rated in the U.S. Most 3-1/4 HP routers are rated at 15 amps @ 120 vac. Actual voltage can vary between 110 and 120 depending on the service load. (Average is about 117) This means one of these routers would run between 1650 - 1800 watts. The Bosch 1617 is rated between 2 - 2-1/4 HP depending on which motor is involved, all are rated at 12 amps. Today I purchased the new Bosch MRC23EVSK which is rated at 2.3 HP and 15 amps. Is this confusing enough? My take on all this is the Bosch 1617 has a lot more power than a PC 690 (rated at 1.5 HP), a little more power than the PC 890 series routers (rated at 2-1/4 HP). As I test out the new "23" I expect to feel more power than with the 1617, perhaps as much as my PC 7518 (rated 3-1/4 HP). Time will tell, watch for the review.
