You can have the same issue trying to fit routers to router table insert plates. Since you are building guitars you may want to do inlays at some point and to do that you'll need to get and use at least a couple sizes of guide bushings. You can use the guide bushings and the plastic base plate to locate holes that you drill yourself in some cases.
