1 - 7 of 7 Posts
· Registered
Hi,
I read a lot of interesting info on this forum. I was out of woodworking for some time. Its a hobby, but didn't have time for iz lately.
Recently bought Bosch GMF 1600CE. Im quite happy with it, its an upgrade from Makita RP0900.
Is it possible to set heigth when tablemounted in fixed base with a little key provided, WITHOUT releasing body clamp under table?
As i see it now, its not possible??? Little dissaponting
Tnx
· Registered
you must release the clamp....
· Registered
You might be able to release the clamp from above the table, check your manual.
· Registered
Discussion Starter · #5 ·
In the manual, there is not much about table mounting. That's why i thought maybe im doing someting wrong. Its a bit complicated to unlock the clamp every time i want to change the bit heigth. But looks like that is the way it is, unfortunately. Thanks guys
· Registered
Probably the worst thing about this router, of which I own 2 of the US model, is the manual. Be warned about what can happen
1 - 7 of 7 Posts
