do you want a ZC plate for 45° cuts??
I use the Fast Cap zero clearance strips on the factory wide slot metal insert and cut it on a 45°. They also work good on the vertical or any other degree cut. they are cheap and come in packs of 5. Homedepot and Walmart also sell them or buy them direct online.I know this is not a router question but there is a lot of experiance here so I need some advice.
I bought a Bosch 4100-09 table saw for a steal from the Home Depot store ( was floor model ) and was missing the table insert.
I bought a plastic insert from amazon.ca ( zero clearance ) to fit and I will be making a couple out of plywood.
In the meantime has anyone ever also made the cut in the plate with the blade at a 45 dgree cut.
By the way I made my kitchen cabinet doors but they did not turn out as good as they should be so I will remake them ( mistakes cost money and that is a great lession ).
thanks Stuart
