the PC router fit into the Bosch base??? is this what you are asking...Would the Porter Cable 690 LR router fit in this base as well
Stuart
YES, according to page 15 of the RA1171 instruction manual listing compatible routers. While the Bosch 1617 uses a 4 screw pattern for its sub-base plate, under that plate is a second set of tapped holes in the PC 690 trianglular pattern. Using the "B" mounting configuration, you should be able to match up either the 1617 or the 690.Would the Porter Cable 690 LR router fit in this base as well
Stuart
That would definitely be no.I believe the OP wanted to know if the 690 motor would fit into the 1617's fixed base not the table...
