Hello all,
I am in the market for a box joint router bit to join the sides of small boxes. A couple years ago I bought a Whiteside finger joint Bit, but after one test cut, I realized that it was not what I needed. It was meant to rout a joint to either widen or lengthen two boards.
I had to sell it at a major loss, as I could not return because of it being used for test cuts.
I now want to purchase what I initially wanted, but don’t want to make the same mistake twice. So I want a BOX JOINT BIT and not a FINGER JOINT BIT.
Do any of you have a recommendation of a quality box joint bit, that is easy to setup and use.
I have seen where some of them are adjustable. Would that be difficult to use, or should I buy a fixed, say 1/8” or 1/4” joints?
Thanks for any guidance or direction that you might offer.
Sent from my iPhone using Tapatalk
