Many ask where to get the brass setup bars at a good price to use on the hand router or the router table..
You can order the 12" long brass key stock and cut it into 2 or 3 parts, this way you will have 2 or 3 true complete sets ,I like to use the 6" long ones,they will always make the jump over just about any hole in the router table plate ..
Brass Stock ▼
" Made from alloy 360 brass, which contains lead for good machinability. It's corrosion resistant and nonmagnetic. Minimum tensile strength is 40,000 psi. Minimum Rockwell hardness is B35.
Tolerances: 1/8" to 1/2" sizes: ±0.0035"; 5/8" to 1" sizes: ±0.0045"; 1 1/4" size: ±0.005"."
McMaster-Carr
McMaster-Carr
If you want to save more money select Alum. in the normal sizes it's soft and will not harm your bits..(1/8" to 1/2" ) but not in all the sizes like the brass bars...
Brass Stock ▼
McMaster-Carr
McMaster-Carr
