Sounds to me like routing too fast, and possibly too deep (depending on how fast you were moving the router).
I'd use a tablesaw w/ a FTG or TCG blade for that groove...Thanks for the replies!
I don't think I was feeding too fast, probably on the slower side if anything as the piece was small (4"x4"). One other point is that the stock is 3/8" deep (which is I trying to cut a groove half way (3/16"). That reminds me, I was using a push block and push stick for the cut -- wonder if uneven pressure somewhere could've been a technique failure...
I don't recall exactly, but I think the first 1/2" went in smooth, and then I heard the cracking (and instant shake), but I could be wrong.
Any time I can I like to make a cut on the table saw to remove some to most of the waste. That does two things.I did end up making the cuts using a TS (with sled) and two side by side passes but with an ATB blade as I don't own a flat top blade. I may try and chisel the bottom but probably unnecessary as this is the groove for the inside of a box.
Good points regarding the type of bit itself -- webpage for the one I used says "wood, plywood, and composites" whereas the double flute one Stick links to specifically says "hardwood" -- not sure if it's just a marketing difference...
There have been several mentions of going too fast... Although I didn't think so, I guess it's always possible.
Thanks again everyone!
1... clean it up w/ the router or a router plane...1... I did end up making the cuts using a TS (with sled) and two side by side passes but with an ATB blade as I don't own a flat top blade. I may try and chisel the bottom but probably unnecessary as this is the groove for the inside of a box.
2... Good points regarding the type of bit itself -- webpage for the one I used says "wood, plywood, and composites" whereas the double flute one Stick links to specifically says "hardwood" -- not sure if it's just a marketing difference...
I was definitely trying to hold it against the fence! I thought moving right to left on a router table pulled it towards the fence ?If your bit was pulling the work piece away from the fence, and you were trying to hold it against the fence, then it's possible you got into a bind with uneven pressure holding the piece and the bit snapped. I would just take lighter passes or do what Stick said.
David
Welcome to the Router Forums.(looked like a drill hole that wandered a quarter inch)
