1 - 20 of 43 Posts
Discussion Starter #1
The plastic handle on my miter saw broke. The part is no longer available from the manufacturer. I have it held together with rubber straps but would like to try and glue/epoxy it. Would like suggestions on what glue or epoxy to use. Thank You.
I would use a two part epoxy or a solvent-type glue for plastics. Epoxy bonds to almost anything. Solvent glues work for most but not all plastics. I wouldn't trust anything else to bond to plastic.
Has anyone used those plastic welders they sell at Harbor Freight? they come with filler rods and have different rods for different plastics. I read an article one time and I guess they really work. They are not that expensive either.
my dentist does....
but a bit upscale from HF...
Which saw do you have...?
Got a picture of the break...?
I saw an epoxy at a Home Hardware store up here but I can not remember the name of the epoxy. It will even glue hypalon which I am not sure any other one will glue but the stuff was expensive, about $20 for the 2 tubes.
Jim ~ I have had excellent results with Loctite 20 minute epoxy plastic bonder in the .85 fl oz double barrel tube for gluing plastic. Doesn't work with all plastics. I repaired a lawn mower throttle assembly with it and submitted a review to Lowe's. Click ... here ... and click on the reviews button and scroll down to lawn mower throttle repair. Good luck.
Bob
Premium Member
I've had good results using JB weld as well. I've also used Lepages (I think?) 5 min epoxy.
Reactions: Moz
Of course yours probably broke in a different place, but mine has held nicely the past two years with just black electrical tape.
Jim...if it broke over a hollow part of the handle, reinforce it first by fitting in a piece of wood...regardless of what you use for glue...just a thought...
Reactions: Moz
what saw do you have...
1 - 20 of 43 Posts
