1 - 5 of 5 Posts
· Registered
Today I found out how to connect the drill controller to the new drufel bsmce04u-pp.
I own an old Tonsen cnc machine with a card that communicates via parallel port with the pc. This is not acceptable now so that's the reason I decided to change it with this USB card.
If you want PWM signal you have to connect ACM with DCM together and give 10V to the appropriate pin or to connect 5V to 10V together. This will provide power to the PWM circuit and you will receive the signal from AVI. Also you must set at spindle tab the PWM output.
If you feather information just ask.
Thank you.
· Official Greeter
G'day @sv1eps , welcome to the forum.
· Official Greeter
Agreed. This, to me, is the base use for the forum.....
1 - 5 of 5 Posts
