I need some major help from you guys and / or gals that have experience in templates and bull nose bits. I am very open to any and all suggestions because I am getting flat stumped.
1) I am a custom lure maker and I want to make a flat sided crank bait. I am trying to use a bull nose bit to round the top (back) and the bottom (belly)
2) I do not want to lose any fingers. So if this can not be done safely, then I will trash the idea.
3) The type of wood I will be using is cedar, poplar and other wood like them. The size of the wood is: 1/2" thick and I am talking about routing a lure that is 2 3/4" long.
4) I have tried doing this without a touter table and can't figure this out. I have a table on the way so either way will be okay.
5) I have made a template and will show you a photo at the end of the post. I have never made a template for routing.......so I may have started off wrong from the get go.
6) One of the problems I ran into was: their is 1/8" of flat bit on each end of the bull nose bit. So the template needs to be adjusted for this.
7) the bull nose bit I have is 1/2 "
hopefully this is enough information for somone to help me out. If not, just ask for what you need and I will try to provide the information. If I can figure out how to load the photo, here it is.
thanks, Tally
thanks, Tally
