21 - 30 of 30 Posts
· Registered
I have 2 Freud Industrial blades which worked great on remodeling my kitchen. I cut a lot of maple with no problems. I have a Freud Industrial 24T rip blade and a Freud Industrial Cabinet Makers 60T blade. My Freud blades are made in Italy. I think they work great on my old Unisaw 3hp saw.
· Registered
What are you cutting? How thick?
If you are satisfied with the fence, blade alignment and feed rate, that only leaves the blade. In my experience, the Tenryu 24 tooth full kerf rip blade will give you a much better cut than any red blade. Actually, almost any other decent rip blade (Amana, Forrest WWII, Infinity, Carbide Processor s, etc) will far out perform those crappy red blades.
Fine Woodworking did a comparison on all the popular combo blades, in the current issue. The Freud red blade was rated #1for cleanest rip and crosscut. It was downrated for slow rip rate. They offered the Forrest or the Ridge as faster ripping alternatives at the cost of a little rougher cut. My only experiene with Freud was a 12" in a miter saw. It was thin kerf and had no stabilizers, so it was probably partially my fault for a bad choice, but the it was terrible. I could never get a repeatable cut. A standard kerf Forrest fixed all.
Sent from my SM-G900V using Tapatalk
· Registered
I don't buy red either...
· Registered
Time to clean up several of my blades. I cut a fair amount of pine. One last suspect. I got a pretty good straight edge not long ago and discovered that the face was slightly warped, not by much, but even a few thousandths bulge would cause problems. If the fence were truly flat, the readout from near to far would be gradual and fairly steady, but it isn't. I think a wood fence would be more prone to this.
· Retired Moderator
Is Charles M still on the forums?
You can find out by finding a post he made and clicking on his user name and going to his personal profile. There is a menu bar there with the word statistics on it and when you click on that it gives you the opportunity to see all the posts he made, threads he started, and when his last activity was.
21 - 30 of 30 Posts
