1 - 20 of 31 Posts
· Registered
I don't know what else to do here....this morning I went through the owner's manual to try to correct whatever might be wrong, but I don't seem to be getting it at all......
I re-aligned the rip fence, I checked the squareness of the blade, I got a brand new blade, I re-installed the splitter (which I removed because it was not aligned and I didn't know how to align it at the time) and aligned it.
Today I actually got a full rip out of cherrywood with zero burns....I don't know how I did it though...
I rip plywood with no burns. I rip pine with hardly any burns(but there are burn marks sometimes). I rip oak and cherry wood and the wood has burn marks on it! I'm only ripping through 3/4 stock here....I don't think it should have any problems with that!
I'm using a brand new Freud Premier Fusion blade on a Hitachi portable table saw. I set up the ripping fence with a carpenter's square and lock it into position while it's flush with the square.
Does anyone have any ideas how I could better set up my machine or any suggestions on how I could figure out what's going on here.....this is frustrating.....
· Registered
Tpyke, the only thing I can think of might be the speed you are feeding the saw. You don't want to try and force the saw to cut. I would expect some burning on pine or high sap woods but the hard woods should cut smoother. On the other hand too slow can cause burning also. You have to get a feel for the type wood you are cutting.
· Premium Member
I don't think it's the blade but, to completely rule it out, try using a different blade. Speed still has a lot to do with burning as well. If you have extra scrap pieces, try running at different speeds to "fine tune" your feed speed. Another thing, you may be moving the piece every so slightly away from the fence putting the blade "in a bind". Hope this helps.
· Registered
Discussion Starter · #4 ·
I think we can rule out the blade, because I was getting the same results with the original blade that came with the table saw. I got this blade thinking the problem would be solved, but....
· Premium Member
Try changing your feeding speed.
· Registered
Discussion Starter · #6 ·
I'm going to have the chance to experiment today (Ihope...)
Two last things that are bugging me though....
Blade heigth-I've been placing the blade heigth so that the teeth go up past the piece of wood...in other words if you look at it from the side you can always see at least one full tooth. If I place the blade higher, less teeth would be in contact at the same time, so would there be less chance of burning?
Fence alignment-I heard that some people align the back of their fence slightly away from the blade...is this common practice? Is the fence parrallel to the blade the norm?
· Registered
Your blade height is about ideal. Do you have the printed insert that is included with the P410? It has tips for setting the fence and the blade height as well as a troubleshooting section.
· Registered
Hi tpyke
Just a long...
Most carpenter's squares are NOT true, this comes from the size most of the time, try using a smaller machinist square and use the miter slot on both ends of the table top.( front and back) ..in fact drop the blade all the way down and setup the fence once you have that done do it one more time then rip some stock, if you still have burn marks reset the saw blade so it's runnng true to the miter slot.
If you still have burn marks ,glue on some sand paper to the saw blade ( both sides) ( the one that came with the table saw) 180 grit. paper ,this will cut and sand all the parts you rip....I use this little trick when I cut plywood vern. and Oak... :)
· Premium Member
· Registered
tpyke
quote "Cherry works well with both hand and machine tools. Keep your blades and bits sharp and keep the wood moving. The natural gums in cherry burn very easily. A fraction of a second pause in feeding can result in a heat build-up which leaves dark burn marks that are hard to remove. Some pieces are crossgrained and no matter which way you plane, tear-out results."
Got this information off a web page. I have worked with some cherry and it does burn. Sharp blade and speed control are a must. If burning persists, perhaps adjust the width to accomadate a pass over a jointer to clean it up. Here's a pic of my cherry wood project.
· Registered
Discussion Starter · #11 ·
Nice work Woodchip7! That cherry wood seems ALOT darker and browner than mine though....did you stain or treat it with anything?
You were all right about my feeding speed though...gotta keep it moving!
The thing is my saw seems to have a hard time when I push it fast enough to not burn....I should have a bigger more industrial saw I think, but I had no choice...limited space. Plus I didn't know about this forum back then, so I didn't know too much about woodworking.
This is the saw I have:http://www.hitachipowertools.com/store_item.php?iID=555&arrPath=1,12,63,p555, ....you guys think it should be able to take the 3/4 cherrywood or might I be pushing it a bit too fast?
· Registered
tpyke
Cherry will darken with age. I believe I hand rubbed the cherry with tung oil, no stain. I really liked working with the Cherry. Would love to get my hands on some more at a reasonable price. Years ago a popular ww mag use to publish an article on different tree species. Had valuable infor such as uses and how to handle cutting as well as health risks etc. Wish they would do that again. Maple is another wood you gotta be careful with. Sounds like you need more HP in your saw. I'm guessing the one you got there isn't much more that maybe 1 1/2hp if that. Had that problem with the ShopSmith saw I also own. If you don't have the hp make sure your blade is always sharp. I'm in the middle of renovating my shop but am anxious to get my new toys hooked up. Powermatic PM200 TS with 3 HP and a Powermatic 8" Jointer. Winter here in lower Minnesota has kinda put a damper on shop time. Heat bill last month running shop heater was over $600. Good luck with your Cherry wood project.
· Registered
Hi tpyke
It didn't say anything about HP but it pulls 15amp. at full load and 4000 rpms.
The real key is a good SHARP blade ..( I recommend Freud 60 or 80 tooth) the 80 is for cross cuts but it works great on rips also...the thiner the better for me no need to put good wood down the tube.... :) plus it takes less power to make a pile of saw dust...
Plus when I rip with the 80 I love to see the long rip strips come off the stock..:)
The saw you have should do the job I think,,,
· Registered
Discussion Starter · #14 ·
GOOD! That's what I'm using...60 tooth Freud(full kerf, though).
The last thing I needed was to have a feeling I had to upgrade my TS....too many other tools on the wish list!:p
I just checked in the instruction manual, and it says:
HP(Maximum developed)..............3.5
RPM(no load).............................5000
What does "Maximum developed" mean?
Could it only lose 1000 RPMs from no load to full load?
Could they be sugar coating the manual?:'(
· Registered
Hi tpyke
"Could they be sugar coating the manual?" Little bit like most do,, :)
Because that's what most look at ( HP )
Just like a router ..
No load, no saw blade installed :) almost free spin...
· Premium Member
To get the most hp from your TS, use the thin kerf blades. As Bj said, less waste and easier for the TS to cut/rip. I prefer using a higher tooth count and or a combo blade, due to the fact it leaves a smoother cut.
· Registered
Although you can rip with most any blade, I highly recommend that you avoid trying to rip with 60T or greater. These are dedicated crosscut blades and will be most likely to burn and will wear quickly. A good rule of thumb is to have 3 to 5 teeth working in the wood when ripping. That makes the ideal blade for ripping 3/4" stock 24 to 50 teeth. More is not always better - fewer teeth and an aggressive hook angle will make the saw seem more powerful.
· Registered
Hi tpyke
The sand paper on the saw blade WORKS great,, give it shot. if you don't like it you can always take it off...I use 3M #77 spray glue...I also like to use 8" blades they are cheaper and I don't cut 2 x 4 stock on a 45 most of the time...
You can also buy them pre made but you know me cheap old SOB :)
http://www.grizzly.com/products/G4246
1 - 20 of 31 Posts
