Cabinet door hinge router bit question
4601 Views 10 Replies 4 Participants Last post by  Herb Stoops
I'm making a couple of cabinets and need a router bit for the hinges. I want to use the same kind of hinges to match my old cabinets and I'll need to have a router bit.
This image is the kind of hinge and bit I think I need. Also, is there an easy jig I can get to go with this kind of bit? If so, what do you recommend?
1 - 11 of 11 Posts
got part numbers???
bigger pictures???
No information yet, I'll have to check that out. And that picture was just from Google Images of the style of hinge I have on the existing cabinets.
I'll work on it.
link me...
link me...
My kitchen cabinets have a 3/8 inset but Rockler doesn't carry those, only 1/4" or 1/2".
I think I'll go with Amazon 3/8" inset
https://www.amazon.com/Amerock-BPR8...keywords=double+demountable+hinge+3/8+overlay
Or Rockler's 1/2" inset
Double Demountable Hinges | Rockler Woodworking and Hardware
Wouldn't the router bit be the same for either?
up spiral cutter for the cut in a plunge based trim router...
you are making a small mortise that wants straight walls and not radiused...
make a clamp on stop which is nothing more than piece of ply cut to look like a ''U'' w/ the legs far enough apart to accommodate the router and length of cut...
add a leg to the ''U'' to form a ''T'' to facilitate better clamping and if you add a gusset for strength and stability to it you'll be ahead in the game..
the cut out for the stop...
make the throat a lot smaller.. and while you are at, make it a slot and not an open throat..
use a guide bushing on your router and let the router ride on top of the stop... now the router will be less likely to ''rock/tip'' as you cut...
this what you want???
Thanks! It will be a while before I get to the stage in my project before I'm actually cutting, I'm just getting ready.
5
What I made and used...
Reactions: 2
Be sure to practice on some scrap before the real thing.
1 - 11 of 11 Posts
