Infinity Premium Glass Door bit set. The stile bit cuts a very thin slot forming the back of the frame, then another very thin bit is used to make a second cut to remove material to form the area for the glass and to make a small glazing strip to hold the glass in place. Problem, even on lowest speed setting and moderate smooth movement these tiny bits overheat. Anyone else experience same with this or other glass door bits?
