You hold the scraper flat on your work bench with you left hand (if your right handed) sharpen the edge with the burnishing tool, flip it over do the same thing to the other side.You realy have to wip the heck out of it .. then stand it up in a vice and run your burnishing tool flat across the edge til you can fell the berr with you finger nails when running them up the side. when you fell this your done ..good luck. It is realy easy
Learning Herb
