Hi, YLP: welcome to the forum. a bit in a round base router may not be centered, or the router could have some runout, If you put an arrow or a mark on the router base
right where it rides your guide ( or square) you can then use the guide with the mark
for all the rest of the cuts. When making repetitive cuts I use guide bars and an edge guide, if they are going to be equal saped apart. After making the first dato the edge guide goes into that dato and lines up the next cut. Hope this helps. Woodnut65
