Hi All,
My name is Mike and I'm new to the forum. Unfortunately my first post will be one asking for help. I just received my Carve Wright “C”. I watched the instruction video, checked head pressure (which is at 88.1 lbs). I made a quick test carve in the software and set out to give it a run. It went thru a series of tests and started carving. The machine made it to 1% complete and gave me a “Y” axis stall E05-0303 error. I pulled the board out of the machine and cleaned it with an air compressor (keep in mind it is brand new) and tried it again. I received many more errors over the next hour of trying to get the machine to carve. The errors are as follows.
“X” axis stall E06-0303 error
Please load board (the board was loaded)
Check tracking roller
Check for board problem
Check back roller
Before I purchased the Carve Wright I spent time reading about the issues, most seemed to be “user” errors and I’m sure most of these are “user” errors. I appreciate any and all comments on these issues.
Thank you
Check back roller
Thank you
