Hi Corey
Here's one or two of them ▼
http://www.routerforums.com/tool-swap-n-sell/4323-looking-glue-pot-2.html#post41564
It's a GREAT tool
,,,,I'm happy so far, I have run into a design error or two but that's just me
They have a MUFFER and a dust bag (all in one) on it that can't hold to may chips/saw dust and with it off the DB is about 150 or more so it's a real ear prot.is a must.
I did rework that part of the system, I don't want anybuddy to call the cops when I run it....
(it was that loud but not now )
The bits are a pain to change, they are held in by 2 small Allen cap screws that have been put in with LocTite, so I needed to heat the Adapter up just a bit to break the seal (hey that's a good tip for someone ) so I said that sucks so I sent off for 4ea. 1/4" and 4ea. for 1/2" adapters,they are cheap only 3.50 bucks ea..that makes it nice.
They have a GREAT 1/8" bit that will cut a 3/4" board like butter without breaking, so I sent off for some of them also, plus some other bits as well and a extra 8meg. memory card
JUST Note about the 1/8" bit ,it's like the RotoZip bit in a way, but it's 1/4" shank ,it's like a upcut and a down cut bit on the same shank, the cutter is about 1 1/4" long and 2 1/2" over all long, and razor sharp
high end carb.....
BCT125 Cutting Bit
http://www.carvewright.com/pricing.html
All in all, 4 stars out of 5 stars so far.
The key pad on the machine is a hard one to get down, the manual didn't give that info in deal tail, so I asked Charles M. (member of the forum) for some help on that one and like a champ he had the info I needed.
I guess I should post that just incase someone needs it .
Bj
I think you're getting it but just to be sure, if you want to carve a piece that is 12 X 12 you will need to add at least 3-1/2" on each end. There are two options to do this:
1: Set the board dimensions to 12" X 19" in Designer and center the carving on the board. Using this method you would NOT choose the "Keep under Rollers" option.
2: Make the board 12" X 12" in the Designer program, use a 12 X 19 board and choose the K.U.R. option and Center on the Board.
If you are also going to cut out the carving or shape the edges you need to add at least 1/2" to each side in the width. The resulting board would have to be at least 13 X 19.
Does that help? ( Charles M.)
Bj
