That turned out really well John. Like the horizontal grain look to
For sure going outdoors at leaqst 8 months of the year. That's why I got PTL. Brutal weather in the Upper. The cedar had too many knots. I've had them hold up pretty good with water seal applied to slow down the graying.Pressure treated is almost always yellow pine if it came from the Southeast of USA. With it as wet as it was I hope it stays flat.
I like the design. Will it be used outdoors? Maybe you should make him another out of a better wood for indoors too.
Charley
It's starting to warp on the top and bottom. Any ideas. Will probably have to make another and got back to the stain and spar varnish.Pressure treated is almost always yellow pine if it came from the Southeast of USA. With it as wet as it was I hope it stays flat.
Charley
I think this is the real answer. Do you have a moisture meter? I think for anyone making this kind of sign or plaque, that would be a must If the wood is stacked face to face, it will take much longer to dry, and pine is pretty much a sponge for any moisture around.A month in the garage is not nearly enough time for it to dry. And until it's dry, it's always going to warp.
Mike,The sign looks great. You are doing a good job with your lettering now. One thing you might consider is composite decking for outdoor signs but that also depends on the brand from what I'm told. Not all of it is made the same and some is just too porous on the inside for 3D.
Is yours porous on the inside or would it be solid enough to carve well?Mike,
I have quite a bit of scrap pieces of Trex decking that I kept as I was going to try and cnc something with it, but I am not sure what to do with it as it is just black inside. Maybe it would be good enough contrast for text signs, but unless you can paint like Scott, I don't think it would be much good for 2.5d work.
john did you do this on the probotix or did you use the cncrp pro?
