Hey guys, I started cleaning up the Cedar that I sawed earlier this year. I cut them into 1", 3/4" & 1/2" boards (and a few 2"X 8"). There was quite a bit of pecky, worked 2 days going through them marking out usable pieces. Very little small stuff, if it was < 20" I pretty much scrapped it. I did cut out a good pile of really small stuff for corner braces, drawer slides, molding and the like. The drawers of the Chest of Drawers that will be next will have 18" drawers (that's where the 20" comes from. The Cedar Chests will be roughly 4ft X 2ft X 2ft. I have more boards than I need and still have about half of the logs to process.
My question is;
since most of the boards are 4"-10" wide, do I cut them down and glue them (alternating the grain) when I am making the side & top panels? I hate to do that but if they are going to warp...I will. A friend of mine tells me to cut them into at most, 4" wide boards & glue them back together (alternating the grain)
Also, can I glue in thin strips of different kinds of hardwoods (say 1/2" or even 1") of Red Oak or Hickory or Sweet Gum) to add character. It just occurred to me that it might look nice to have a different color between every Cedar 1X4. I consider the Cedar a soft wood compared to the Oak and Hickory. Don't know it soft and hard woods can be glued together.
The Sweet Gum isn't nearly dry yet, cut it 3 weeks ago. That is some different wood for sure. It is turning brown as it dries. I shaved of the edge on one on my table saw check the color and it is almost pure white inside! And so fine grained that I really can't see the grain on the edges. I'm still tossing around ideas as this is my first project!
One more question:
I have a lot of the 1/2" thick boards. Can I glue them together to make the bottoms of the drawers, or is it better to make them out of something like a hardwood plywood? Still assuming I will have to cut them narrow & glue them back together!
Once again, thanks for all you help and willingness to share you knowledge and experience!
My question is;
One more question:
