Welcome to the Forum!
I don't have a Makita router but I am sure they have a provision for centering the bit in the sub base.
I know of two systems one is a round disk with 1/4" hole in the center. The disk is the same size as the guide bushing and fits in place of a guide bushing. A alignment shaft is mounted in the router and you loosen the sub base screws and with the shaft in the disk you retighten them.
The second type is a cone type where a shaft with a cone shape is put in the router and a guide bushing is put in the sub base, again the sub base screws are loosened and the cone is used to center sub base.
Some routers come with these but for others you will need to purchase the parts.
A less then perfect way is to eyeball it.... In my early days I did this but it was a lot less perfect then I liked but then again maybe it was just me..... Anyway you can give it a try and at least get to the point of not taking off part of the guide bushings.
Hope this helps
Ed
Hope this helps
Ed
