Centering your router on a mounting plate
41918 Views 61 Replies 37 Participants Last post by  niswanger
It is very important that your router be centered on your mounting plate. Many people sweat over this for hours remeasuring before they drill their mounting holes. The quick and easy way to do this is with a centering kit from Rousseau. These kits work with all brands of mounting plates that accept Porter Cable style guide bushings and they cost $5.
Step 1. You chuck up the centering pin in your routers 1/4" collet.
Step 2. Insert the disk into the center hole of your mounting plate.
Step 3. Remove the sub base plate from your router, set it and the screws aside.
Step 4. Install the transfer screws into your routers base with the points facing out.
Step 5. place the centering pin into the disk, position your router to face the direction you want it mounted and lightly tap the edge of your router with a mallet. This marks the locations you need to drill.
Step 6. Drill the holes, flip the plate over and slightly countersink them.
Step 7. Using the new screws that came in the centering kit attach your router and it is perfectly centered.
If you are using a plate that accepts the larger Oak Park style guide bushings you can purchase a centering disk and a guide pin from them. You can purchase transfer screws from most hardware stores or tool suppliers.
1 - 1 of 62 Posts
centering the mounting plate and bit to the plate
this is what i did i put in a guide bushing in the plate up side down use a big opening guide and use a round bottom bit or a 45 degree bit and brought the bit to the guide bushing. That center the bit to the guide bushing which centered the plate . Tighten the plate to the router. Works for me or have i been lucky ???
1 - 1 of 62 Posts
