I've had good results wrapping tightly with electrical tape. Of course, I also try to grab the plug itself when I unplug whatever.Standard wire colors, I presume. I'd find a plug with a cable clamp that can be cinched down on the cord, given the number of times it will be plugged and unplugged.
According to his profile, he is a retired electrician, So, I am thinking he needs to replace the factory cord at the motor connection. Just thinking. I don't want to ASSUME. That doesn't always work out. :frown:There is something called an electrician's knot that keeps the cord from pulling out...used in lamps and other electrical things. Check it out if replacing the entire cord.
Because the 3600Br is double insulated it uses a two core cable so if it's just the mains plug that requires replacing it really doesn't matter which way the Blue and Brown are connected, but if you want to be pedantic then Brown is live and Blue is neutral.How to change the wiring plug on a Makita 3600BR?
Very good post Harry. You get the (At-A-Boy) award for the day. :laugh2:Because the 3600Br is double insulated it uses a two core cable so if it's just the mains plug that requires replacing it really doesn't matter which way the Blue and Brown are connected, but if you want to be pedantic then Brown is live and Blue is neutral.
If however you are replacing the mains cable, then as shown in the photo, the brown and red wires with eyelets go to the switch (missing in the photo) and Blue goes to the joiner. I hope that this helps.
